This problem has got me baffled. This all started before I did any of the current work on the car. This is what I have done so far.
1. Mechanic fuel pump push rod 3/8 short, replaced new one, it is stuck in block, so I added electric fuel pump.
2. Rebuilt AFB again (3 year old rebuild), by a professional he saw no problems, replaced accelerator pump.
3. Electrical fuel pump has built in regulator added a pressure gauge. Regulator reading 5 psi near engine could not get the pump to adjust, replaced with another new pump, set it at 6 psi
I still have the problem. It starts and idles fine I can drive it up to about 40-50 mph under easy acceleration and then it cuts out. If I punch it after it is warmed up I have 3 to 4 seconds until it cuts out. It will kick in the 4 barrel and sounds great until it dies.
I can take my foot off the gas and it will always come back to life after coasting for a couple of seconds. I can always limp it home driving about 30-40 mph.
Fuel pump installation. Mounted below the lowest point of the tank (recommended location). There is about 12 inches of rubber hose from sending unit to pump with a clear fuel filter in between. I have an unobstructed flow from the tank, I can remove the inlet line from the pump and it flows out freely.
One note the fuel pump is suppose to be adjustable from 5 psi to 10 psi. The second one I got to go up to 6 psi (which is what I was told to set the pressure) Is this correct? I don't think it will go to the 10psi level. I already have it adjusted nearly the whole way in.
It is acting exactly the same way as it was before I did any of the current work, no change at all.
