poisonr98
well my 66 fury had a fire yesterday and it was depressing watching my build engine go up in flames and the engine wiring harness. i put it out with a full bottle of antifreeze in the backseat i had. thank god it worked cause i think i saved my motor itself. the plumbing carb,wiring harness, and distributer are done. but there is a upside to this. i found a 440 with a 727 with only 37000 miles out of a 68 newport for 500 buck. my car was originally a 383 car that someone put a built 318 with x heads and cam and other stuff in there. if i pull that 318 and the small block mounts will the 440 mount in my k frame and does anyone have a wiring harness for the engine i could buy from you
