Dominique Williams
Hi, I've probably already have asked this but I recently changed out my oil and the gauge started to act wonking the needle is jumping after driving awhile when warming up and driving for 20-25mins the psi stays at 60 but after awhile it will go to 90, 120, and 140 when stopping at a light but as soon as driving it goes back down to 60. I changed my oil pump and cleaned out the new one took it apart and everything nothing is in the oil pan because I figured if the feeder is stuck it would be losing pressure not gaining or if the relief valve was stuck or opened but I've been reseraching if their was high oil pressure it would of blown the oil filter off clean with those spikes but it hasn't happened (knock on wood) so im thinking that the gauge or sensor is faulty has anybody had this problem before
