Exhaust leak, my broken bolt
GOLDMYN
Chilton Wi
Hi, well, I finally got the ambition to tackle an exhaust leak in my 68 newyorker. soaked them all in Koil , I told my wife before heading out. This job NEVER ends up good. Sure enough, #6 never gave a warning, just twisted off. I'm going to attempt the repair by drilling out the remained. question I have. Which right angle drill would be best to purchase. I appreciate your comments.
If this is the only time you may use it, buy a Harbor Fright for $30. 3/8 in. Variable Speed Reversible Close Quarters Drill
There are better ones... and ones that may last longer etc., but this should get the job done and it's $30. Find a coupon and it's even cheaper.
These should work, although be very careful with the extractor. Bust one of those off and it gets serious. I usually give them a quick try and if it doesn't walk right out, I go back to drilling.
Screw Extractor and Left-Hand Drill Bit Combo Set, 10 Pc.
That will be very difficult to get the hole centered for the extractor. I've had great success with this tool for the same job but it's pricey, it has a drill guide that centers the hole perfectly. It has to have a little bit of the stud sticking out to work, it looks like you have some threads left to screw in to. As an alternative you could make your own drill guide by center drilling a bolt & then cutting off a length. Just some thoughts, would beat out removing head.
Snap-on Store
You need to be very careful that you get the hole drilled centered and straight. If it is drilled crooked, the extractor will usually break or the other thing that happens is the treads get damaged by the drill bit. I usually pull the head to change studs, but try to drill first if you are comfortable doing that. If you drill a small hole thru the stud first, you can use the wand on the spray can of penetrating oil to force oil to the back side of the stud and then drill the appropriate sized hole for the extractor. The left hand drill bits are a good idea as mentioned. Oil to the back side of the stud will make removing it easier.
Little off topic but your engine appears to be running quite rich based on your exhaust port.
Snap-on Store
I have those, use them quite a bit. I find they work best when the broken bolt is recessed a bit.
I don't want to be a downer, but when I have had a stud or bolt break while removing it. I usually can't get it to come out with a extractor. It's rusted so much it won't budge, most of the time I drill them all the way out.
^This^
I never have much, if any luck with an extractor either. Occasionally, they will work, but you really can't crank on them, especially at that size. A broken extractor is a nightmare.
^This^
I have broken both extractors and drill bits, the best way I have found to get them out is with a 1/8 inch carbide bit and grinder, it's little bigger then a dental drill, but sounds just like it. We have both straight and 90 degree grinders at work.
Hey everyone, Thanks for the great comments. Looks like taking the head off is the safest.
If you are going to pull the head, this would be an excellent time to replace all of the studs. These studs cold work over time from the repeated heating and cooling and get very brittle, and they also stretch, that was probably what caused your exhaust leak. Few things are more annoying that replacing the one damaged stud and bolting everything back together and having another one break. Any good auto machine shop can remove and replace the old studs and it is not terribly expensive.
