Front Disc Conversion Kits for a 14" wheels?
64custom880
Baton Rouge, LA, USA
Hello. My 1964 Dodge custom 880 has 14" inch wheels and I don't want to upgrade to 15" wheels. Can anyone recommend front disc conversion kits that work with 14" wheels...most 1964 mopar kits requires at a minimum 15" wheels.
Imperialist67
Washington, DC
Look around through the forums on this site, there is a LOT of info. on this conversion, and really good advice. The kits differ widely in terms of quality and stopping power. I THINK I read that Willwood has a kit for 14" wheels, but don't quote me on it. Good luck.
SGT FURY
Northern California
If you want to keep your 14in hubcaps? You can use disc brake 14in rims from a 73 up dart or scamp with disc brakes. Or 14in rallye wheels with your hubcap
64custom880
Exactly lol. I really don't feel like looking for some original hubcaps for 15" wheel.
Here is a link to a PST kit? What are your thoughts?
Front Spindle Mount Disc Brake Conversion Kit
I also want a kit that brake pads are easy available and has the ability to stop this boat.
Sixpactogo
Wisconsin
I was thinking I used the front disc's off of an A body when I did my 60 Dodge Dart back about 20 years ago. What ever I used, they work fine with the stock 14" wheels. If I remember correctly it was 78-80 Dodge Aspen. I'm sure there are others and quite possibly the aftermarket these days.
JEP
Ohio
I bought 1/4 inch wheel spacers, which pushed the rim out far enough where the rim didn’t rub the caliper.
Imperialist67
Washington, DC
Hadn't thought about this - great advice, in case I ever want to upgrade my '67 to discs up front. THANKS.
1970FuryConv
Richmond, VA
Interesting. Did the spacer have proper indents for the lugs and leave enough stud thread contact area to be safe? What Manufacturer did you use? Thanks
1970FuryConv
Richmond, VA
Technically, I believe a 1978 Dodge Aspen is an F-body. A-body ended production in 1976
bnz84
Maryland
These guys have been around for a long time and were one of the first to offer a conversion using a bracket and brake parts off of other makes. I run an older conversion not meant for 14" wheels but it has worked great and been reliable. On the other hand you will get a number of people here that don't like scarebird in general so be sure to get both sides as to why. Some of the concern is related the machined spacer that allows the rotor to center on the spindle. No doubt not a factor style.
Scarebird 1964 880
