SF-66TC
Just completed stripping and POR15 my LCA's, Strut Rods & Sway Bar and getting ready to reassemble everything. Replacing UCA's with Firm Feels Tubular Arms, Front RCD Bilstein Shocks, Rare Parts Strut Rod Bushings, NOS LCA Bushings, Rare Parts Diamond Series Lower Ball Joints and Pitman Arm, PST's Front Stabilizer Links & Moog's Sway Bar Bushings.
Need help with clarification on the toque specs for reassembly. Looked in my FSM and just need clarification that I'm understanding which pieces are which. I think I got everything correct other than I'm unsure about the "Steering Knuckle" Is this the Lower Ball Joints arm that attaches to the spindle? If so, I understand the Lower, but what is the Upper?
Specs are in ft/lbs unless stated in in/lbs (which is just the sway bar hanger nut)
Torque Specs - 66 Town & Country
Ball Joint
Stud Nut - Lower (to LCA) - 115
Stud Nut - Upper - 100
Control Arm
UCA Cam Bolt Nut to Frame - 65
LCA Pivot Shaft Nut to Cross Member - 180
Steering Knuckle - is this the LBJ assembly?
Lower Bolt Nut ????
Upper Bolt Nut ????
Strut Rod
Strut Rod Nuts at LCA (rear nut) - 100
Strut Rod Nuts at Cross Member (front bushing) - 40
Sway Bar - Front
Sway Bar Hanger Link to Frame Nut (top) - 100 in/lbs
Sway Bar Cushion Strap/Retainer Nuts - 30
Shock Absorber - Front
Lower Nut (LCA) - 55
Upper Nut (frame) - 25
Ball Joint
Control Arm
Lower Bolt Nut ????
Upper Bolt Nut ????
Strut Rod
Sway Bar - Front
