Fuel sender unit
Electrical & Ignition
  1. bluefury361
    bluefury361 Old Man with a Hat
    13,133
    9595
    Mar 9, 2011
    Alabama Gulf Coast
    I got everything on the dash working now except the fuel gage. The indicator comes off the peg and stops at the empty mark. Good signal and good ground. I suspect the sender. Has anyone had good results with one of the aftermarket senders on the market? Their pretty proud of the NOS units I've seen.
  2. stubs300
    stubs300 Senior Member
    2,732
    1105
    Oct 30, 2011
    Free America
    You sure you got gas in the tank, if so how much? You can pull the sender and test it out of the vehicle. Just leave it hooked up and connect a good ground wire to the sender unit. Have a helper supply power, as you move the float, the gauge will/should move. It may take a few seconds for the gauge to read float level. This has worked for me a few times. Good Luck
    • Thanks! Thanks! x 1
    • Agree Agree x 1
  3. Big_John
    13,490
    8325
    May 21, 2013
    Marcellus, NY
    I had no problem.
    They all seem to be from the same vendor, so shop around. My best deal, and quickest shipping, was Amazon.
    I did solder a tab on the sender for a good ground... A much better, more reliable ground than the grounding clip on the line.
    My adventures with gas gauge senders and a Meter Match, which while I used it to "fine tune" the gauge, and it was fun to play with, I don't know as I needed to buy one. Gas Gauge Fix
    • Like Like x 1
  4. Big_John
    13,490
    8325
    May 21, 2013
    Marcellus, NY
    • Agree Agree x 1
  5. stubs300
    2,732
    1105
    Oct 30, 2011
    Free America
  6. Pete Kaczmarski
    Pete Kaczmarski Senior Member
    2,476
    1573
    Oct 11, 2012
    Waupun WI.
    About six weeks ago I had the same problem with my 1970 Plymouth Fury gas gauge. Same issues and diagnoses. I purchased a sending unit from vansauto.com It works fine and I'm happy with the product. It came with a gasket and retainer ring.
  7. CBODY67
    CBODY67 Old Man with a Hat
    5,300
    1210
    Mar 27, 2011
    The "guts" of the sender is the rheostat-type mechanism which the contact on the float arm "wipes" to vary the resistance in the circuit. In other words, the only "wear part" other than the float and the float arm's pivot point.
    Anybody tried to clean-up the wiped comtact area, out of curiousity? Or see if the wiping contact has worn too much?
    Just curious,
  8. HWYCRZR
    HWYCRZR Senior Member FCBO Gold Member
    2,799
    3581
    May 13, 2015
    Fargo, ND
