1. 66furywagon
    66furywagon Well-Known Member
    550
    170
    Nov 2, 2013
    indiana
    Does anybody make a aftermarket
    Brake booster and master cylinder kit
    For a 66 fury.
    Wanting to put power brakes on the wagon.
    66 fury2 wagon auto with a big block
  2. crazyboutwagons
    crazyboutwagons Well-Known Member FCBO Gold Member
    526
    278
    Dec 7, 2011
    Pittsburgh,Pa
    BOOSTER DEWEY (POWERBRAKE BOOSTER EXCHANGE 503-238-8882) best choice for rebuilt booster . should be able to help you with both items. If you have manual brakes now you will need the brake pedal & rod from a power brake car they are different. will not be cheap core or core charge for both item's . Cardone rebuilds from parts stores are usually junk not reliable. good luck
  3. Davea Lux
    8,012
    1971
    Mar 27, 2017
    Cornelius Or
    Your best bet if this was a manual brake car would be to locate a parts car with power brakes and buy the complete setup. The midland booster for drum brakes is not that uncommon, but finding the appropriate mounting plate and pedal assembly can be difficult. Concur on Booster Dewey as a good quality rebuilder.
  4. Imperialist67
    Imperialist67 Senior Member FCBO Gold Member
    1,071
    323
    Jul 16, 2013
    Washington, DC
    Sounds like something Murray Park would have, especially if you need a complete setup. Not sure what shipping would be like from his part of Ohio to where you are, worth looking into regardless.
    Good luck, sounds like a major upgrade, but brakes are a real good place to invest in!
    • Agree Agree x 1
  5. Wollfen
    Wollfen Old Man with a Hat
    6,833
    3537
    Jul 18, 2012
    Greenville NC
  6. 66furywagon
    550
    170
    Nov 2, 2013
    indiana
  7. pixbypops
    pixbypops New Member
    12
    0
    Apr 17, 2017
    clarksville tn
    I used aPST kit. not cheap but includes everything.
  8. 66furywagon
    550
    170
    Nov 2, 2013
    indiana
    Can i get more info on this kit
  9. pixbypops
    12
    0
    Apr 17, 2017
    clarksville tn
    go to PST.com or to vendor list here on the forum. they give a discount to members
  10. Wollfen
    6,833
    3537
    Jul 18, 2012
    Greenville NC
    I checked the mount holes of the adapter bracket on this unit and it matches up perfectly with the original firewall hole on a non power brake car, I also measured the length of the rod that goes through the firewall, the kit includes three different length units and the shortest one is less that a 1/4in longer than the factory rod on the back of the non power master cylinder. I would say it will work and simply adjust the brake light button actuator after installation.
