1966-300
I have a 1966 300 as you can likely guess. My question is this. Is there a special tool to remove the clips that are used to hold the front wheel well rubber flaps, the same ones are used for the hood to cowl front radiator seal. And other areas they look to be a simple design kind of a rounded triangle but I have tried pliers and other methods to remove them there must be a better way. I attached a half A$$ed drawing if it helps.
