This is an easy install and a reliable replacement for the fragile and troublesome worm drive motors. Only one 1/4" hole has to be drilled for the bottom bracket. The system is a power off close so a single SPST switch can be used if your car was not an original hideaway car or the Mopar relay is toast. You can also activate the relays off a marker or low beam circuit. Power feeds from starter relay terminal, and grounds on core support ground terminal. The kit includes: Actuator and mounting hardware, pre-wired fuse protected relay pack, new polymer support bearing with steel cage, complete instructions and email support if needed. This is a bolt on for 3rd Gen Chargers so other models will require a custom lower bracket. Paypal or MO accepted just PM me for more info.
Thank you FCBO!
Thank you FCBO!
