live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,676
- Reaction score
- 8,881
In other threads you will see that I've been working on my heart box. I have it installed in the car, but have a leak when I slide the lever to warm. The leak is between the heater pipes that connect to the heater core. See pictures below.
heater pipes
Heater core connections.
Because this is an AC car it has a dual core. The lower tube in the second picture is the inlet which is an "h" valve that controls whether coolant goes to one or both cores. The upper is the return to the engine.
Each tube gets a o ring to seal the connection. The bottom connection leaks like a sieve. I'm sure that I've tried the o ring that came with it and numerous others.
I was told that because I glass bead blasted the pipes and inside the connections I probably took "meat" off the inside causing them to not seal. I bought another box and took the pipes off it. To me it looked like someone used a lot of blue permetex on it years ago.
I almost forgot. As a last ditch effort I used Ultra Black gasket maker Saturday evening. I waited more than the 24 hours it says and it still leaked.
I've got some o rings coming from a local company a few towns over and I may order some from Mcmaster.com as well.
Has anyone else had this issue? How did you get it to seal up?
