Uncle Salty
i need to know what i have to remove?install, as to the factory charging system, regulator, ballast resistor etc I have a 1965 chrysler windsor, canadian version of newport. I have removed the factory 383cui engine and cable shift trans and have replaced it with a 1978 440 cui engine and later make of 727 trans. The manufacturer of this distributor (TSP) states this is a simple 2 wire hookup procedure with the red wire being hooked up to the positive terminal on the coil and the black wire to the negative terminal on the coil. what happens to factory components? help with this issue would be very greatly appreciated, i'm probably overthinking this issue but am stumped for the time being lol
