Dhink802
75 Coronet 400/4bbl, just quit running while ideling in driveway. Will not restart. Sounds different then before. Where should I start? Fuel sys? or Ele sys? and what about that ballast resistor?
Don't bother.outta gas would be my #1 culprit of not running :laughing6:
Don't bother.
After my answer he never came back...:eusa_clap:
Don't bother.
75 Coronet 400/4bbl, just quit running while ideling in driveway. Will not restart. Sounds different then before. Where should I start? Fuel sys? or Ele sys? and what about that ballast resistor? HELP Dale 419-351-4401 [email protected]
:Groaner: SOME PEOPLE???? i would do a compression test first, since you say is sounds different could have jumped time? nylon gears an is very common. also could be valvetrain related.
He was having a girly man panic attack. If he was really interested he would have come back for AT LEAST a second post.Everyone has something to say with keyboard muscles, theres the number call Dale and find out what happened......:toilet04:
Geezz stop beating around the bush and say what you really mean LOLHe was having a girly man panic attack. .....
Hi Guys! It was the timing chain. Original aluminum timing gear was almost smooth with all the teeth almost gone. THANKS ANYWAY,
and YES, I will probably not waste my time posting here again.....
Girly-men. No appreciation what so ever...Your welcome. Jeeezzz, talk about gratitude.
