yellowkeeble
I chnaged the rear leaf springs and shocks on my 67 Fury II 2-Dr and have a 6" difference in height between passenegr and driver side rear. I swapped the springs to see if the lean moved with the spring and it remained the same ( passenegr side). I see no damage to the frame or leaf spring brackets, or mounting hardware. I plan on inspecting the rest of the frame for a crack or something obvious but all door gaps are fine and fender fit is pretty good. The car is an original 318 car and I pulled the motor out a couple weeks ago but didn't notice if there was a lean. I have only had the car 4 months or so and have never seen a with full drivetrain or driving. Am I missing something obvious????
Ernie
Ernie
