Hey all, thanks again for prior responses to my other question and thanks in advance for this one too...
chrysler hidden headlight relay...i tried to troubleshoot it...saw no voltage at the bulkhead connectors 25 and 29 with key on and headlight switch on...so I figured it was a bad relay.
I did the tyco replacement from this thread:
need headlight relay for 71 fury (the new relay had 85 and 86 switched from the pic, opposite sides of the relay..is this ok...not main question)
No joy after the switch. In tracing where the problem might be, i got continuity on the "light green" wire from the headlight switch to where it connects to the relay but never saw any voltage indicating the switch is "on"?
What should i see when switch on, 12 volts? If i should maybe the switch is bad?
the headlights do work; low and high beams...
Thanks gurus!!!!
Thanks gurus!!!!
