Fast Eddie B
78 NYB. Manual says 'slide the fuse box toward the center of the car to remove it from the bracket'
I can see a couple of relays poking out. I can grab the box, but nothing is 'sliding' anywhere!
And where is the 'center of the car? To slide it on a 45 degree angle to the center of the car, you would have to go through the metal dash! If they mean 'slide to the right toward the steering column' it ain't moving and if i try any harder I'll just break something.
Clearly there is a trick. This is very annoying as it should be SIMPLE to see a fuse box!
Thanks in advance to anyone who can help.
