How often do you shift your Torqueflite out of "D"?
Early C Bodies - The Slab Side Years
  1. EurekaSevven
    EurekaSevven Member
    54
    10
    Jan 14, 2021
    North Carolina
    I had this question in my head for a while now, as when I bought my Newport, it came with the original owner's manual. One of the pages in it was describing when to shift the TorqueFlite when in different situations, such as using "2" when going down curvy country roads that require more controls, and using "1" for steep hills going up and down hill.
    Do you guys actually use this method, or do you keep it in Drive the entire trip?
  2. Wildbunch02
    Wildbunch02 Senior Member
    2,709
    213
    Dec 8, 2017
    Long Island
    That applies to all vehicles, it all depends on what the driving conditions call for. Under normal driving conditions it stays in drive.
    • Agree Agree x 4
  3. 71Polara383
    71Polara383 Kid with ballcap
    3,092
    4939
    Dec 10, 2016
    Rockford,IL
    All the time.
    • Like Like x 1
  4. live4theking
    live4theking Old Man with a Hat
    10,768
    2949
    Nov 24, 2014
    Rockland; Venango County Pennsylvania
    I frequently downshift everything I drive when going down steep hills. If I'm hauling a load I'll downshift going uphill as well at times.
    • Agree Agree x 2
  5. WissaMan
    WissaMan Well-Known Member FCBO Gold Member
    510
    388
    Sep 12, 2018
    Northeast PA, 10 minutes from Knoebels Grove
    I manually downshift when approaching long down grades. I also downshift manually if I know I'm going to need some speed, since it doesn't have part throttle downshifting. When possible, I shift when there's not a lot of load on the drive line. i.e. I anticipate the situation and downshift rather than wait until I'm already flying down hill or got the pedal (almost) to the metal. I figure it's easier on the transmission that way and will help it live longer.
    I do this with all my AT vehicles, not just the old Chryslers...
    • Agree Agree x 1
  6. EurekaSevven
    EurekaSevven Member
    54
    10
    Jan 14, 2021
    North Carolina
    I've often heard and seen truckers doing the same thing when approaching a downgrade, one video in particular I remember was something to the effect of shifting a gear below the "proper" gear for the speed limit (such as in a 10 speed using 10th gear to go 55), and using your Jake Brake to keep your low speed. As with trucks, they use air brakes, and using them too much will light you on fire.
    Probably a wise thing to do also for a TF and if you have drum brakes (such as mine), and I live in a more mountainous area, although I haven't really taken my Newport out onto the steeper grades, not until I get the brakes in tip top shape anyways (mine still work currently, but I don't know if they've ever been replaced, and my master cylinder needs a replace for safety).
  7. commando1
    commando1 Old Man With a Hat on the Porch
    35,359
    19833
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    It's an automatic FFS...
    • Like Like x 2
    • Thanks! Thanks! x 1
    • Agree Agree x 1
  8. NY69
    NY69 Member
    147
    97
    Oct 17, 2014
    NL, NB
    Within city limits (35 mph speed limit) I drive my a/t cars in 2.
    Less shifting = less wear, more comfort and better fuel mileage.
  9. azblackhemi
    azblackhemi Old Man with a Hat FCBO Gold Member
    6,363
    4525
    Nov 13, 2010
    Waddell AZ
    I shift out of D when I go backwards and when I park!
    • Like Like x 8
    • Agree Agree x 5
  10. 3C's & a D?
    3C's & a D? Senior Member
    1,486
    478
    Oct 27, 2015
    By the tree in Edmonton
    Absolutely necessary when going through a tunnel!
    • Like Like x 2
  11. WissaMan
    510
    388
    Sep 12, 2018
    What's absolutely necessary for me when going through a tunnel is: windows open, downshift, floor it
    just love that sound :icon_fU:
    • Like Like x 2
  12. Zymurgy
    Zymurgy Old Man with a Hat FCBO Gold Member
    6,393
    5008
    Sep 14, 2012
    London, Ohio
    I have a center console so I just naturally reach to downshift if a curve requires to slow to a speed of 35 or less, just to get more power out of the curve. Otherwise coming out of the curve it will just stay in 3rd unless you punch it.
    • Agree Agree x 1
  13. luigi164
    luigi164 Active Member
    353
    196
    Oct 8, 2014
    Breda, The Netherlands
    Only downhill to 2nd or first, otherwise always in D....So here in the Netherlands just in D but when in Germany at the BBTR . . :D:D:D
  14. mrfury68
    mrfury68 Senior Member
    1,267
    460
    Jul 15, 2015
    Bethel Park PA
    There are a lot of steep hills here in southwestern Pennsylvania so down shifting when going down hills always made sense so I wouldn't overheat the brakes.
    • Agree Agree x 2
    • Like Like x 1
  15. Turboomni
    Turboomni Old Man with a Hat
    5,926
    3399
    Dec 14, 2015
    MA
    My 69 doesn't have part throttle down shift so sometimes I do it manually when cruising at 35 or so at the base of a long hill to accelerate up it. Not that I really need to with a 440 but it must be abit easier on the trans.
  16. bronze turbine
    bronze turbine New Member
    39
    20
    Apr 26, 2019
    Berwick, PA
    2.5 tons downhill + drum brakes = 2. If you leave it in D bye bye brakes.
    2 going up hill if it starts pinging.
    • Agree Agree x 2
  17. 300rag
    300rag Waiting out the storm FCBO Gold Member
    13,156
    14885
    Dec 4, 2010
    Calgary, Alberta, Canada
    The rule I learned was go down the hill in the same gear you would go up it. The new vehicles downshift for you now if you have the cruise set and it coasts to over 5 mph above your set speed.
  18. GregG48203
    GregG48203 Active Member
    359
    277
    Dec 15, 2015
    Detroit MI
    The only automatic I would ever occasionally manually shift was my 1988 Diplomat. If I wanted to accelerate quicker, I would briefly hold the car in "2" before upshifting. In order to meet CAFE requirements through the 1980s, automatics were programmed to shift early. This was less of an issue as fuel injection became more ubiquitous.
  19. mr. fix it
    mr. fix it Old Man with a Hat
    7,720
    5938
    Aug 14, 2013
    Habitating in Kingston, NS
    Yes
    I use 2nd to try to maintain a safe steeper down hill speed
  20. Minneapolis Bill
    Minneapolis Bill New Member
    33
    7
    Feb 3, 2021
    Minneapolis MN
    Lived in San Francisco for 20 years, downshifted on hills all the time. Keeps you from burning up the brakes.
    • Agree Agree x 1
