Biggredd2069
68 Newport 383. Can't find in search...Do you need to lift the engine to replace the oil pan gasket? I can get by how it is now but does have a small drip from it. Wouldn't mind to replace it and think I can do the work myself but just need to confirm if I need to lift the engine. If so, I've seen a jack method which is questionable. I could probably get a cherry picker. Do you just remove an engine mount bolt and raise it up with whatever method you go with?
