64Imperial
Hey I cannot for the life of me get the speedometer cable out of the housing! I'm trying to install auto pilot on my non auto pilot car. Does anyone have an suggestions?
I removed the retainer and bolt but it still won't pull out! I don't cause damage but it's driving me nuts lol I've pulled on it and twisted itOK- yes you have to remove the retainer bolt and clip to pull the housing/cable out at the trans end. I guess I just assumed you understood that.
Perhaps the earlier stuff is made totally different but I don't think so.
Please correct me if I am wrong.
Good luck.
I definitely think it's just been there since it rolled out of the factory and rusted to it! I sprayed it with pb blaster and tomorrow I'm going to find the thinnest flat head screwdriver I own and pry it out! LolI agree if the bolt and retainer have been removed it will come out. Maybe hard, but it should.
If it's been in there since it was new, it may take quite some work to get it loose.
Positive vibes from Virginia that all goes well with the screwdriver, and you're celebrating with a cold one earlier than expected!I definitely think it's just been there since it rolled out of the factory and rusted to it! I sprayed it with pb blaster and tomorrow I'm going to find the thinnest flat head screwdriver I own and pry it out! Lol
I just had an ordeal putting disks on the front and the bolts going through the spindle and backing plate were so locked up I had to drill some out! It was a mess! Not even heating it worked so I've just been fed up with stuff not pulling out like it should lol
