I have researched the HP of the 440 in my 300.
I have found different HP's.
Some say 350 and others say 375.
Does anyone know the true HP?
Thanks Commando1.350
375 was not available until 67
There's a bunch of good guys here you can always turn to.
As always...Where does that put you?
As always...
At the RR station waiting for my ship to come in.:gah:
Somebody gets it...:toilet04:me thinks you is 'ship' outta luck on this ride.....
I have the TNT dual snorkel air cleaner. so it has 365HP? This car was purchased in August of 1966.As we all know, the 440 was introduced in 1966. There were two versions that year. The first was a 350hp version. The second, introduced for the 66 1/2 models had 365hp.
This second version is a bit interesting. It was labelled by Chrysler as a 440TNT, but wasn't the full out TNT that was introduced for the '67 model year, as it still had logs.
The fifth digit in the VIN is a J, indicates 440.There seems to be very little information available for the 365bhp engines. As far as I am aware, the only differences are the dual snorkel filter, and a 2 1/2" exhaust until the muffler exit, when it goes down to 2 1/4".
As part of another project, I recently dynoed a "near enough" 365, and found that it made the same amount of hp as a 375hp engine, but had a better torque curve.
You should be able to tell from the VIN number which engine was originally fitted.
Ok, I will check it later and get back to you.If you look on the fender tag, the bottom row of numbers should start 82 if its a 365hp engine. If what I have just read is correct, that is!
all the 440 where overated from the factory
