Inboard or outboard?
Heating, Cooling & AC
  1. swisherred
    swisherred Well-Known Member
    895
    444
    Jan 19, 2016
    winston salem, nc
    Would this 26" radiator be considered inboard or outboard on the upper hose?
  2. Davea Lux
    Davea Lux Senior Member FCBO Gold Member
    4,955
    1295
    Mar 27, 2017
    Cornelius Or
    Mopar used two configurations on 26" radiators, One with the outlet on the driver side and one with the outlet on the passenger side. Never heard them referred to as inboard or outboard.
    • Agree Agree x 9
  3. swisherred
    895
    444
    Jan 19, 2016
    winston salem, nc
    Even the fsm refers to them as in or out. This isn't the original radiator for my car...it was replaced. I have swapped the yoke out for an ac car yoke so now it fits....but I want to ditch the flex hose that was used.
  4. polara71
    polara71 Old Man with a Hat
    39,678
    7418
    Nov 16, 2010
    New Jersey
    That photo and the mounting studs makes me wanna go look at my radiator .
  5. mrfury68
    mrfury68 Well-Known Member
    886
    320
    Jul 15, 2015
    Bethel Park PA
    Those studs are for the shroud. Upper rad hose is on passenger side. Looks just like the one in my '68 Fury, 383 with A/C.
    • Like Like x 1
    • Thanks! Thanks! x 1
    • Agree Agree x 1
  6. 1970cat
    1970cat Senior Member FCBO Gold Member
    2,750
    1173
    Dec 10, 2012
    central ny
    in and out = inlet and outlet as far as i know.
    • Agree Agree x 4
  7. MoparJim
    MoparJim Member
    161
    170
    Mar 18, 2017
    Oakdale, California
    I was thinking the exact same thing: This looks exactly like my radiator set up in my 68 Sport Fury 383 with AC. In fact, although I don't claim to be any kind of expert, I have been around and interested in these cars since they were new and I don't recall ever seeing the radiator hoses any different than on this example.
  8. 65sporty
    65sporty Old Man with a Hat
    6,739
    1575
    Aug 24, 2013
    Marlette,Mi
    So your just looking for a new hose?
  9. 300rag
    300rag Grumpy Old Man With a Hat FCBO Gold Member
    11,032
    11479
    Dec 4, 2010
    Calgary, Alberta, Canada
    Not to muddy the waters here, but could this be the reference of inboard/outboard? Yes, I know it's a different application, but you get the idea with the location of the inlet.
  10. 1970cat
    2,750
    1173
    Dec 10, 2012
    central ny
    where did you find those pictures? looks like a 22" i need.
  11. CBODY67
    CBODY67 Senior Member
    3,954
    910
    Mar 27, 2011
    Upper hose for a B-block a/c car (passenger side of the tank outlet) is very similar to the one on the B/E-body 383s with a/c. Mostly the same contours. Might require a bit of shortening at the t/stat end, as I recall.
    Personally, I'd term the upper picture, with the hose near the filler neck, as "center" rather than "inboard".
  12. 300rag
    11,032
    11479
    Dec 4, 2010
  13. polara71
    39,678
    7418
    Nov 16, 2010
    New Jersey
    Thanks, I can leave the hood closed .
  14. swisherred
    895
    444
    Jan 19, 2016
    winston salem, nc
    Those radiator pics are exactly what I meant. The upper one is inboard...lower pic is outboard. They had 22 26 and 28" radiators. Some inboard, some outboard depending on big block or small block. I want to make sure I get the correct upper hose for mine. The lowers were the same.
  15. live4theking
    live4theking Old Man with a Hat
    8,069
    1761
    Nov 24, 2014
    Rockland; Venango County Pennsylvania
    What engine is in your car? Also, which way does your t-stat point.
    My 68 NYer with AC has the inlet on the passenger side. The t-stat points to the passenger side as well. Purchasing am upper hose was not a problem, but I had to buy 3 lowers to get one that would fit and then like someone else said I had to shorten it.
    Rock Auto listing for 68.
  16. swisherred
    895
    444
    Jan 19, 2016
    winston salem, nc
    67 383. Stat points straight up. Water pump to the drivers side.
  17. live4theking
    8,069
    1761
    Nov 24, 2014
    Silly me mine points straight up too. At that rate one for a 68 NYer should do fine for the top. I guess the thing that could throw you off is if the distance from the radiator support tip the engine is different.
  18. Don A
    Don A New Member
    3
    2
    Dec 12, 2014
    Vernon, Ca
    Small blocks and big blocks without AC had the top hose connection near center or closer to the driver side of the car. Big blocks with AC had the top connection where your picture indicates. Hemi's had the connection in the top passenger side corner for both air and no air applications. Btw, the yoke is generally refereed to as a core support. Note: when you buy new hose's most come with instruction to "cut to fit" and the bottom one is always a small problem because it needs to fit between the lower cross member and the oil filter without touching or rubbing on either. Be sure and use a wire in the bottom hose. It's a tight bend and wire will prevent collapsing the hose under acceleration. The top hose it straight forward and the 90 degree bend slips over the thermostat housing and then shorten the other end if needed to slip on the radiator. The Gates hose pictured above (25804), third one down in the picture, is used on big blocks with AC and Hemi motors ('66-'69) where the radiator connection is on the passenger side. Don A
    • Like Like x 2
  19. swisherred
    895
    444
    Jan 19, 2016
    winston salem, nc
    Thanks guys. I ordered what I think is correct from what y'all are saying. Will find out soon.
