Castle
Looking for opinions.... Does anyone know any reason why a radiator for a 68 that is for a car with A/C, shouldn’t be used in a 68 without A/C.... as long as it’s the same size, 22” for instance?
Unless you’re going for OEM original my rule of thumb for over 30 years is use the biggest you can reasonably jam in there. Never had an issue and I have gone cross species at times. 68 390 mustang rad in a 66 dart w 360 circle track motor. The only issue you’ll ever slam up against doing this mix and match is delta T due to core thickness.Looking for opinions.... Does anyone know any reason why a radiator for a 68 that is for a car with A/C, shouldn’t be used in a 68 without A/C.... as long as it’s the same size, 22” for instance?
The radiator supports are different between 22" and 26" cars. Part od the 26" rad is blocked my the 22" You will have to drill holes in the 22" rad support to mount a 26" rad - lots of people do it.
