1. Rick_S
    Rick_S New Member
    8
    6
    Jul 4, 2020
    Londonderry,NH
    Hi everyone. I'm new to the forums so please forgive me if this question had been answered in a previous post. Question is: Do I need to remove the steering box to replace a leaking input shaft seal or can I remove the 4'' retainer ring with a spanner wrench from above? It's in a 70 Newport. Thanks for any available info. Rick_S
  2. Trace 300 Hurst
    Trace 300 Hurst Professional Tinkerer FCBO Gold Member
    1,601
    937
    May 27, 2018
    Ponte Vedra Beach, FL
    I think you're not getting an answer because we're not sure what you mean by "input shaft", but I'm guessing you mean the steering wheel or "worm" shaft that points towards the firewall. Do you have a Factory Service Manual either paper or an "e" version? Go here: MyMopar - Mopar Forums & Information - Service Manuals
    There is a special tool to remove the worm (steering wheel) shaft seal while in the car, and a similar tool to remove the gear shaft seal under the car. But I don't think you'll be removing that 4" retainer nut either in the car or out out of it. It's holding some serious stuff inside there.
    • Like Like x 1
    • Agree Agree x 1
  3. Rick_S
    Rick_S New Member
    8
    6
    Jul 4, 2020
    Londonderry,NH
    Thanks Trace 300 Hurst. I'll try to remove it using the deck screw extraction method. It is the seal where the steering column connects to the shaft. Tools C-3638 and C-3650 are probably rolling around in the bottom of somebody's abandoned tool box. Wish me luck...Rick_S
    • Like Like x 1
  4. Trace 300 Hurst
    1,601
    937
    May 27, 2018
    Maybe now that we're using the same words, perhaps someone here has some advice or will loan you those tools. I'm sure someone here has 'em, and seal pullers aren't limited to Mopars. It's a common tool in many sizes.
    But deck screws work too!
    • Agree Agree x 1
  5. Rick_S
    Rick_S New Member
    8
    6
    Jul 4, 2020
    Londonderry,NH
    Success! I should have been a dentist. The extraction went as planned. New seal, no leaks, Life is Good once again. I also want to thank all who welcomed me to the C body community.
    • Like Like x 5
  6. Trace 300 Hurst
    1,601
    937
    May 27, 2018
    If you really want some thanks from the Cbod community, you'd write up a nice "How To" on your dentistry work, including pics of the deck-screwed seal. :thumbsup:
    • Like Like x 2
    • Agree Agree x 1
  7. 3175375
    3175375 Senior Member
    1,652
    1917
    May 16, 2018
    Centerville, South Dakota
    Good work! As @Trace 300 Hurst stated, a write up with pictures would be great for us to steal knowledge from!
    • Like Like x 1
    • Agree Agree x 1
  8. Rick_S
    Rick_S New Member
    8
    6
    Jul 4, 2020
    Londonderry,NH
    I'll try to make a futile after the fact instruction of what I did. Step 1: Disconnect the battery 2:Drive out drift pin in the coupling (pic-1) 3: Disconnect shift linkage ( in park position) 4: Remove access cover (pic- 4) under dash 5:Remove shift indicator rod on column. 6: Remove (2) column (3) flange bolts on the firewall(pic-3) 7: Support steering column with jack stand (pic-5) and remove (3) nuts from column support plate. The column assy should be free to pull back and separate from the input shaft at this point and position to allow for a little room to work in. Moving on to (pic-6) I used a #43 drill bit for the seal. It's a tight space to get in to (pic-8). I had to recess the bit into the drill equal to the length of the shaft with a little extra. In regards to the screw,it was just laying around in my vast unorganized inventory of loose hardware. Something similar to the drill size should work. You'll only need a few turns as the seal housing is soft metal. (pic-7) is the vice grip I used along with a small claw hammer in between the steering box housing to jack out the seal. Once removed clean out the area around the input shaft. Apply a thin layer of grease to the inner lip and outside edge area of the new seal . I used a 3/4'' deep socket to tap the seal back in. Not the ideal tool but works OK if you're careful. That's basically it other than start engine...check for a leak and reassemble in the reverse order. Hopefully.this tidbit will be useful to a member or two.
    • Thanks! Thanks! x 4
  9. Trace 300 Hurst
    1,601
    937
    May 27, 2018
    I think that's a darn good tidbit that many folks might put to use in the coming years. Knowing that this common problem can be solved using your method, what with the very tight quarters involved, is half the battle.
    Good write-up, thanks.
    • Agree Agree x 1
  10. Samplingman
    Samplingman Old Man with a Hat
    5,087
    2957
    Apr 18, 2012
    South Jersey
    Thanks for the write-up, I did the same operation with the pitman arm seal. Of course after that I noticed the worm shaft seal was leaking also so I’ll be tackling that this week.
    Here is a pic of my pitman arm seal extraction. That 1 5/16 nut was the hardest part. Why do they have to be torqued to 180 foot pounds?
  11. Trace 300 Hurst
    1,601
    937
    May 27, 2018
    So the pitman arm doesn't fall off?
    (Nice work, BTW)
    • Thanks! Thanks! x 1
  12. Rick_S
    Rick_S New Member
    8
    6
    Jul 4, 2020
    Londonderry,NH
  13. Rick_S
    Rick_S New Member
    8
    6
    Jul 4, 2020
    Londonderry,NH
    I believe 180 ft lbs is an industry standard spec for a nut of that size for that particular application. I have never heard of a pitman arm falling off as it is basically pressed onto splined shaft with little space to travel even if the nut did fall off also contributing to the difficulty of removal to access the seal. Looks like you've removed the whole steering box. If you did the pitman seal the input shaft seal is not nearly as challenging.
    • Agree Agree x 1
  14. Samplingman
    5,087
    2957
    Apr 18, 2012
    South Jersey
    Yep, the box is out. I’m trying to do everything I can before the engine goes back in, since right now it is very difficult for me to get under the car. My torque wrench goes up to 150. I’ll do that and then give it one more good pull with the breaker bar, should be good enough.
    • Agree Agree x 1
