Journey of my 68 Newport
Early C Bodies - The Slab Side Years
  1. Big_John
    10,687
    5,627
    May 21, 2013
    Marcellus, NY
    This looks like what they did... Mostly on page 2, but you can see what's up and why they do this mod.
    Catalog
    I'm not really 100% on board with this mod but many have done it this way.
    • Agree Agree x 1
  2. Big_John
    10,687
    5,627
    May 21, 2013
    Marcellus, NY
    Looks like the ground for the washer pump.
    • Agree Agree x 4
    • Thanks! Thanks! x 1
  3. BLUPORT
    BLUPORT Loves everyone, except Carmine. FCBO Gold Member
    500
    368
    Dec 10, 2018
    Eastern NC
    That would also explain the dead alternator gauge.
    • Agree Agree x 1
  4. Yeahrightgreer
    Yeahrightgreer Well-Known Member
    837
    472
    Oct 16, 2017
    Camp Lejeune, NC
    Well I’m no pro at all - but I’m more than willing to lend an extra set of hands and I’m somewhat competent
    • Like Like x 4
  5. BLUPORT
    500
    368
    Dec 10, 2018
    Eastern NC
    Wait... there's no way to pull the old distributor and drop in the new one without screwing up my timing, is there?
  6. Carmine
    Carmine Old Man with a Hat FCBO Gold Member
    5,132
    4,215
    Feb 22, 2015
    Detroit 'burbs
    Scribe a line on the base and onto the engine block. Note which direction the rotor points. Replicate when you reinstall.
  7. LocuMob
    LocuMob Fluid Technician with a hat FCBO Gold Member
    My Photo Garage
    7,983
    4,045
    Oct 31, 2013
    Blue Earth Mn
    Easily set. One of the basics. Put your engine at TDC #1 cylinder and your timing is where you need it to be, then it will be easy to tune it if it's off a little with the new distributor. Remember to line up the rotor to #1 as well.
  8. Big_John
    10,687
    5,627
    May 21, 2013
    Marcellus, NY
    Sorry, but you are going to have to got out the timing light.
    Just point the rotor in the same direction as it was and try to orient the distributor in the same way as the old one.
  9. BLUPORT
    500
    368
    Dec 10, 2018
    Eastern NC
    Dad to the rescue, I'm picking up his timing light tomorrow, I have to go get some cotter hairpins and washers to get the kickdown linkage set properly anyway.
    Maybe a can of seafoam for the tank, and some carb cleaner won't hurt either.
  10. cbarge
    cbarge Senior Member FCBO Gold Member
    1,491
    1,635
    Nov 22, 2010
    Kingston Ontario Eh?
    Heavy black wire goes to stud back of alternator.
    From there it goes to the bulkhead and inside the car spliced to feed ignition switch and discharge side of ammeter gauge.
    Dead ammeter gauge is not surprising to me.
    Unless you want it to work,don't worry about it.
    Wiring has become one of my strong suits on 68 Chrysler's.
    Looks like somebody bypassed the bulkhead as mentioned and that is OK.
    I would simply clean up the wires,close up the exposed black wire.
    Replace the red wire that is cut at starter relay which goes to the red wire that goes through the bulkhead.
    Add a wire from the battery stud back of alternator,run it to the battery stud at starter relay use a fusible link or in line fuse.
    If you want to monitor the charging system and do not want to pull the dash,install an aftermarket voltmeter gauge.
  11. BLUPORT
    500
    368
    Dec 10, 2018
    Eastern NC
    My radio monitors voltage discretely, and shows it on my phone, so I'll just leave the dash as is. I'll grab some good primary wire while I'm out tomorrow!
    • Like Like x 1
  12. BLUPORT
    500
    368
    Dec 10, 2018
    Eastern NC
    ...of course I wake up today feeling like my guts are turning inside out. Daily plans are in the toilet, with the rest of my internals.
  13. BLUPORT
    500
    368
    Dec 10, 2018
    Eastern NC
    Okay, I forgot to post this the other day, so I'm troubleshooting from the toilet... When I connected the kickdown spring, I noticed the carb isn't quite resetting down to full rest. The clip shows what I'm referring to.
  14. Dobalovr
    Dobalovr Friend to Elitists FCBO Gold Member
    My Photo Garage
    4,641
    3,533
    Sep 3, 2015
    Calgary Alberta
    I grabbed this screenshot from the FSM. The throttle return spring is connected wrong and likely the kick down spring is too strong and is overpowering the throttle return.
  15. BLUPORT
    500
    368
    Dec 10, 2018
    Eastern NC
    My initial thought was that it was the kickdown spring, but I tested it with the kickdown spring off, and it's the same. I can try moving the throttle return spring and see if that helps, along with a healthy dose of carb cleaner.
    I'm still on the fence about getting the new distributor, can't decide if it's worth it or not right now.
    On a side note, I'm planning to clean out my shop, so I'll be able to get to all my tools and setup my workbench again. I won't even be able to get the nose of the car in there, but I won't have to worry about rebuilding the carb in the kitchen.
