leaf springs
San Jose, California
would anyone know where to find to find leaf spring replacements for a 68 fury 3 fast top? and what would be the better options the 5 or 6 leaf along with the appropriate size I would need for the car also.
1970FuryConv
Richmond, VA
I used Eaton Detroit 6-leaf with a 440. I would not use 5-leaf with a big block.
Others here use ESPO for springs.
bluefury361
Alabama Gulf Coast
go to the search box at the top of the page and type leaf springs. it's been a hot topic here for a long time
Look in the FSM downloads to see which engine/model option uses which rear leaf spring. Then "std" or "HD". THEN you can get a better idea of what the car should have AND whether or not you might desire the HD rear springs. As I recall, IF the car had factory a/c, it already had the "HD" front torsion bars, so adding the appropriate rear "HD" spring and a good HD shock should work pretty well.
