looking for 1968 Newport wheel sizes/specs.
Early C Bodies - The Slab Side Years
  1. Mike McGuire
    Mike McGuire Member
    179
    33
    Aug 1, 2016
    new hampshire
    Hello Fellow Mopar fans,
    Sorry for the repeat inquiry (error on my part as I should have posted the rim inquiry bit on the looking for parts section, so FCBO removed the whole post and all replies, since I failed to follow protocol. Again, sorry about that mistake fellers.) but can anyone please let me know /repeat what size 15" rims I can fit inside my 1968 Newport wheel wells?
    15 x 7... x8?
    thanks again,
    Mike
  2. CBODY67
    CBODY67 Old Man with a Hat
    6,059
    1381
    Mar 27, 2011
    Factory equipment, drum brakes was 14x5.5 on sedans, 14x6.5 on wagons. Power disc brakes had 15x6 with 8.45x15 tires. '66 wagons had 9.00x14s on the 14x6.5 wheels. I have P245/70R-14 BFG Advantage T/As on the 14x6.5 wheels on my '67 Newport.
    Factory 15" wheels for consideration. 15x7 "cop car" wheels. 15x6.5" Rallye Wheels from '76-era Charger SE. 15x7 Magnum GT wheels (with no nubs for hub caps, so need a center cap). There was a 15x8 wheel (a 15x7 Magnum GT wheel, without the special metallic paint) that was used on the Volare Kit Cars and are now somewhat $$$$$. The alloy wheels from the '80 Cordobas and similar Dodge Miradas are also options.
    Hope this helps,
    • Thanks! Thanks! x 1
  3. Mike McGuire
    Mike McGuire Member
    179
    33
    Aug 1, 2016
    new hampshire
    Thanks for that again.
    regards,
    Mike
  4. Luke Pokrajac
    Luke Pokrajac Member
    152
    92
    Sep 2, 2019
    Rock Hill, SC (Charlotte Metro)
    15X8 magnum 500's fit just fine on my 68 sport fury.
  5. Mike McGuire
    Mike McGuire Member
    179
    33
    Aug 1, 2016
    new hampshire
    I acquired 15 X 7 rims. wondering if you could recommend the largest size that would safely fit the 68 Newport?
