WANTED Looking for these "screws" - to fix hood scoops
Mopar Parts and Cars Wanted
  1. Stagepirat
    Stagepirat New Member
    0   0   0
    20
    0
    Jun 10, 2018
    Munich / Germany
    Contact Seller
    Hello.
    I'm looking for these "screws". They look very special to me. To be honest I never saw them before. Does anyone of you have an idea where I could get those, or at least how they are called.
    Greetings and than you
    Axel
  2. halifaxhops
    halifaxhops Senior Member FCBO Gold Member
    Rating - 100%
    37   0   0
    1,958
    526
    Mar 10, 2017
    HALIFAX PA
    Fastenal can order them for you.
  3. halifaxhops
    Rating - 100%
    37   0   0
    1,958
    526
    Mar 10, 2017
    HALIFAX PA
    Sorry just saw Germany. I think they are wood studs.
    STUDS-2.jpg Studs designed to be attached by (from left to right): Screwing into wood, bonding into composite and swaging into sheet metal.
  4. Stagepirat
    0   0   0
    20
    0
    Jun 10, 2018
    Munich / Germany
    Thanks. Thats no problem. Is Fastenal a company in the states? Do you have a adress or contact to them?
  5. halifaxhops
    Rating - 100%
    37   0   0
    1,958
    526
    Mar 10, 2017
    HALIFAX PA
  6. Stagepirat
    0   0   0
    20
    0
    Jun 10, 2018
    Munich / Germany
    Thank you very much. I will try to contact them.
  7. 67Monaco
    67Monaco Old Man with a Hat FCBO Gold Member
    0   0   0
    5,753
    2757
    Nov 20, 2010
    Punta Gorda FL
  8. Stagepirat
    0   0   0
    20
    0
    Jun 10, 2018
    Munich / Germany
    Thanks. Is this the normal way to install hood scoops? Or did someone in the past messed something up?
  9. azblackhemi
    azblackhemi Old Man with a Hat FCBO Gold Member
    0   0   0
    6,301
    4475
    Nov 13, 2010
    Waddell AZ
    If anyone is parting a 69-72 Chrysler I think the studs that go in the rear quarter extensions are what you need. Those are made to go in plastic or fiberglass. The 70 New Yorker I parted out had plastic extensions with those same studs.
    • Agree Agree x 1
  10. Moseman
    Moseman Senior Member FCBO Gold Member
    0   0   0
    1,064
    2244
    May 21, 2014
    Longmont, CO
    I am not an expert, but I am sure Chrysler used them often when they had a fibeglass part that need to be attached to sheet metal. MY 78 NYer has those holding the front extension to the fenders. Darn thing rust up, and it generally unsrews from the fiberglass.
  11. 71Polara383
    71Polara383 Kid with ballcap
    0   0   0
    3,054
    4858
    Dec 10, 2016
    Rockford,IL
    70-71 Polara fender extensions as well.
  12. QQE
    QQE Member
    Rating - 100%
    2   0   0
    152
    64
    Jan 27, 2019
    Windber, PA
    We have those and the correct nuts also. Made in our shop
  13. oldkimmer
    oldkimmer Active Member
    0   0   0
    219
    33
    Oct 30, 2019
    Kindersley Saskatchewan Canada
    U can get a hood scoop install kit from the aftermarket suppliers. Lots of A,B,E bodies used them. Layson’s, Classic Industries, A B&E. etc. Kim
  14. Stagepirat
    0   0   0
    20
    0
    Jun 10, 2018
    Munich / Germany
    Thanks. Just found and ordered them.
