Lost of fuel durring ling turn
  1. mathiew
    mathiew Member
    52
    3
    Oct 19, 2017
    Canada
    hi my 1965 chrysler 300 2 barrel lost fuel durring long high speed turn, what it could be?
  2. BLUPORT
    BLUPORT Carpe Diem Cras FCBO Gold Member
    1,142
    889
    Dec 10, 2018
    Eastern NC
    Did it completely shut off, or just sputter? Did it pick right back up and restart/stay running? How much fuel in the tank?
  3. mathiew
    mathiew Member
    52
    3
    Oct 19, 2017
    Canada
    Just sputtering, and stay running, low or full tank!
  4. Davea Lux
    Davea Lux Senior Member FCBO Gold Member
    3,882
    960
    Mar 27, 2017
    Cornelius Or
    Sounds like the float level is set too low or too high. A high float level will slop gas out the top into the throttle bores and try to drown the engine in fuel on a hard turn. A low float level will slop all the fuel to one side away from the jets and starve the engine for fuel. Modern moonshine blend fuels tend to eat up the lead seams on brass floats, eventually this causes the float to get fuel inside and the float will not close tightly. If you are getting black smoke on a hard turn, this is likely what is wrong. Check the fuel filter, if it mostly clogged, the engine might be starving for fuel because of that. If you hit full throttle in a straight line, the engine will run well for a couple of seconds until it sucks the carb dry. That is a sure indicator of a fuel supply issue.
  5. stubs300
    stubs300 Senior Member
    1,564
    591
    Oct 30, 2011
    Free America
    Did the Canucks only get a 2bbl on a 300 in 65? That doesn't sound right?
  6. Davea Lux
    3,882
    960
    Mar 27, 2017
    Cornelius Or
    Engine code for '65 Chrysler 300 383 is AC2 which is the code for 383 4BBL. All of the 300L cars were 413 4BBL.
    • Thanks! Thanks! x 1
  7. Knebel
    Knebel Senior Member
    1,150
    210
    Mar 21, 2013
    Beaverton, Oregon
    ^this...
  8. mathiew
    mathiew Member
    52
    3
    Oct 19, 2017
    Canada
    2 barel
