Fireguyfire
So I’ve dropped my restored 440 engine back into my 70 300 convertible and I’ve tested and reinstalled the factory wiring harnesses on the entire car. The previous owner had installed a generic painless system and the car had all sorts of electro gremlins; luckily he kept all of the original harnesses which I’ve confirmed are good.
Anyways, on the main firewall connector block on the engine bay side tge is a black wire cut off about 3” long. According to my colour wiring diagram it should go to the “low brake warning switch”.
I haven’t had a chance to have a close look yet, but I wanted to confirm that this switch would be on the brake brake proportionaling valve?
And if so, what type of connector does it need there; the 90 degree Rubber boot style?
