Manual to power master cylinder headache
BGarff
Denver, PA
Hi, so I have a 66 fury (manual suicide cylinder) and was hoping some of you might have some insight on a master/booster assembly to use. Preferably high-performance to work with my 12" wilwoods all around. Thanks
A 1967 power brake booster and dual-pot disc brake master cylinder is literally a bolt-in. You need to grab a power brake pedal also (different geometry).
Then you go custom and you're on your own.
Did you install the 12" Willwoods all around?
I can't see the sensibilities of doing that and then leaving the manual single-pot drum brake setup in place. :realcrazy:
Yup I went with an SSBC master/booster assembly that bolts directly in. Should stop on a dime!:rofl:
power brakes dont stop any better
I used to think that too since I stayed with drums all around.
I went with a 1967 dual MC and Power Booster, and PB pedal setup.
I finally learned that i needed the distribution block and now the brakes work 100% although I still have the fun chattering and random left or right pulling from time to time...
I'm on a mission to replace with the stock 73 setup...
