Plymouth man
Does anyone know of any engine mounts I can use to put a 318 in a 68 fury where a slant six used to reside?
www.forcbodiesonly.com
Mounting systems are completely different. Your would need to change the stub frame or find a junk yard car and cut out the V-8 steel supports for the mounts and weld them to your frame.Does anyone know of any engine mounts I can use to put a 318 in a 68 fury where a slant six used to reside?
Yeah I was also wondering if anyone else had tried it but that would be a 180 dollar gamble[/URL]
See also:
[/URL]
This is for A-body because, perhaps, the concept of a slant-6 in a C body was not very common. I wonder how that bracket would bolt-up for the application being considered.
I am planning on doing the same swap. I have a '67 Fury 4 door hard top with a bent stub frame and a nice stub frame from a '67 Fury I that had a slant 6 originally. The diagrams in my service manual show both frames to be the same except where the engine mounts attach. I have another frame from a Fury II that had a 318 but is incomplete and rusted but has good front cross-member mounting brackets.
The way I want to do it is to remove the engine and transmission from the hardtop along with the bent frame then remove the slant 6 brackets from the good frame. Once I have the the 318 brackets from the junk frame removed, I will bolt those with the mounts to the 318 block and after carefully measuring the position, I will attach the rear transmission mount and lower the engine with transmission into position and once the mounts are in the correct spot on the front cross-member, I will weld them in place then put everything back in the car. I think it will be easier that way to get the brackets placed correctly. Careful measuring and patience is the key here I think. I am 81 and working outside so progress is slow but steady.
Amen. I took this week off myself with the goal of working on my fury between the holidays. Then I (we) got an unwanted gift of flu bug in the house. So alas, we rest up while it sits and waits for another (hopefully) mild weekend. RonThank you RGORHAM for the kind words. I do what I can but when bitter cold sets in, work ceases. Once the spring comes, I am hoping to get to work more steadily.
John
I would just weld some wherever i needed them to make it workDoes anyone know of any engine mounts I can use to put a 318 in a 68 fury where a slant six used to reside?
