C Sickness
I have been gradually working through the issues on my new to me 1970 300, which was inop for 30 years. The car now starts and runs reliably. Ive been very gentle driving it around the neighborhood, just light throttle, no W.O.T. starts.
That's a good thing, as the driver side motor mount was sheared. Just a moderate throttle
would at times send the fan into the fan shroud. All mounts are now new.
I checked the new mounts the other day by opening the hood, standing on the brake, and giving it a bit of throttle. Engine torque would make the driver's side of the engine "hike up" against the load. (BTW, it's impressive to see that bonded rubber block in the mount stretch to control the engine against load. No surprise that they want to break.)
During this load test, the engine would sometimes "unload", fall down, and then jerk back up, even though throttle was constant. I think this has also happened while driving with moderate throttle after a stop. There's sometimes a "clunk" or "chuggle".
This makes me think that the transmission plates must be slipping ,momentarily . I have not touched the trans yet, other than confirming the level is correct. On the plus side, the car has only 44K original miles. The minus side is, of course, that it's 50 years old. I'm going to change the fluid and filter. Maybe the filter is "pasted" or restricted, resulting in starvation, and low clutch circuit pressures?
Also, if the car sits a couple days, is started and put into gear, either forward or reverse, the car doesn't move until i give it a bit of throttle. Maybe another indicator that it's "starved", or has "drained back". Once the car warms up, the trans is normal. Drop it into gear, and it will creep.
I saw a good looking 727 book on Amazon. Looks like it could be rebuilt with only a couple special tools, like slide hammers.
I don't know if I can make it run acceptably until rebuild time.
