Does anyone have a 66 era 440 intake diagram with parts callout or vacuum diagram? The small branch of this gizmo is broken and I'm gonna need a replacement. This particular nipple goes on the far rear edge of the intake.
Non ac cars have vacuum operated actuators just like ac cars.Thank You Sir! So if I'm not running AC then I will just need a straight nipple.
Thanks for the help! I don't have air but I am going to run a vacuum gauge. And I found one thru one of the folks over at one of the 440 pages I frequent.As others have pointed out, the larger of the two is for the brake booster with the smaller providing vacuum for accessories such as HVAC, power trunk release and vacuum gauge. The PCV should be connected to the carb base.
