T-revorNobody
"The original color is Carousel Red" - isn't that a Pontiac color?
1962 Plymouth Belvedere - $4,995 - Gardner, Kansas
CL Description
This is a very cool car with a push-button transmission.
The car starts and runs. It needs a new paint job (the original color is carousel red). The speedometer and gas gauge are not currently functioning, so you'll need to replace the 3-panel instrument set. The seats need to be repaired. Serious inquiries only. We got this to fix up and simply haven't had the time, so hoping someone else can bring her back to life.
Engine manufacturer:
Chrysler Slant-6 225
Engine type: spark-ignition 4-stroke
Fuel type: gasoline (petrol)
Fuel system: carburetor
Charge system: naturally-aspirated
Valves per cylinder: 2
Carter BBS 3466S 1-barrel
Horsepower gross: 108 kW / 147 PS / 145 hp (SAE gross)
Torque gross: 292 Nm / 215 ft-lb
Car power to weight ratio net: 57 watt/kg / 26 watt/lb (estimated by a-c)
Car weight to power ratio net: 17.6 kg/kW / 12.9 kg/PS / 28.9 lbs/hp (estimated by a-c)
CL Description
