So we switched from a 2 bbl to a 4 bbl Edelbrock 1406. Along with replacing the floor pans and installing some buckets. Put in some aftermarket gauges also. All was good until my buddy took the wagon out for a test ride this evening. First thing was a loud thumping noise when pressing the brakes. Ok we will check the brakes later. Then the oil pressure dropped to 10 PSI an and he said he could hear the “bearing whine”. I wouldn’t know what that sound is but. They were able to limp it home. This motor doesn’t smoke at all. Not a single puff of smoke at all. Could it just be the oil pump? Is it worth it to just swap out the oil
Pump and see what happens or pull the motor and send it out for a rebuild?
