1. t57f100
    t57f100 Member
    163
    52
    Oct 3, 2016
    connecticut
    hello i have a 65 plymouth fury 318 does anyone know where to get a one piece oil pan gasket i have the stock one but would like a one piece .thank you
    tony
  2. BIGBARNEYCARS
    BIGBARNEYCARS Senior Member FCBO Gold Member
    4,001
    2626
    Dec 10, 2012
    SHADOW OF MOTHER'S PROVING GROUNDZ
    Well Tony, Not Sure if there iz such ah thing az a one piece pan gasket for the 318.(never seen one) What I am sure of iz, to make sure you get to your Mopar Dealer for ah tube of their Black Silicone Gorilla Snot and after you clean and squirt with Brake Clean all 4 cornerz and let it dry. Then you fill those 4 cornerz with ah Goodly Amount where the Pan+Timing Cover+ Block meet. And then let that set up over nite before adding oil, or you'll be doin' it again. I learned that trick in the early '70s when swapping out plastic timing gearz for the good gearz and chains on 3 different '70s Vanz. By the 3rd one I could pull the grill, timing cover and swap gearz and re-assemble in 2 1/2 hourz, and I still keep one of those little white squeeze tubez of that black snot in my stash, Jer
  3. t57f100
    t57f100 Member
    163
    52
    Oct 3, 2016
    connecticut
    thanks so sorry it took so long to return your reply again im sorry
