Oil Weight
frog_dude
The oil weight my 54 Chrysler Windsor asks for is 30W. Is it ok to use 10w-30?
Sure. Remember than the 10 means the viscosity of the oil when cold in your pan. Exactly what you want when you want oil to get to the top of the engine fast upon starting. Once warm, and the hydrocarbons chains transform, then you have 30W. Also 30W back then was SB and today it is SM. The Petroleum Institute would consider any oil put out today, in SB specs, to be a fraud and there are companies that do that.
If you are at all concerned with zinc phosphate and flat tappet engine protection then take a look at the chart just published on five HDEO oils. See zinc.
http://www.pqiamerica.com/May 2013/consolidatedhdeo.html
You might want to try a high zinc oil like Brad Penn 10W30. It's about $5 a quart and worth it to me.
