Let's try this again under the correct forum section...
ops:
Heya all. I'm having an issue with my motor running really hot when at idle after running for a bit.
It's a '66 383/4spd. Last week on a hot & humid day I had it on the road and all was well and it stayed between 160-180 degrees. It ran great and stayed cool...until I got home. When it was parked and idling, it got hot really fast, (well past 210) and spit out almost half a gallon of coolant through the overflow hose.
I know that it wasn't overfilled because I had just checked it, and prior to this happening I didn't notice anything out of the ordinary and hadn't ever had a coolant leak or overflow. It does have an aftermarket radiator from Summit, but it appears to be fine. No leaks or anything else I can see. The engine is in excellent mechanical shape and has under 5k miles after being completely rebuilt/machined.
The only thing I have noticed out of the ordinary is that the radiator cap on it is rated for 7lbs, but the oem cap for this engine without A/C is supposed to be 13lbs. I also know that the cap on it did not come with the radiator and is probably just a universal aftermarket part. I know that the fan and water pump are also fine. My only other thought is that it could be a bad thermostat. I'm far from an expert with this so I realize there's probably stuff I'm not looking at that I should.
Anyone had this happen in the past, or have any ideas? Thanks much in advance for any help!
