mdh157
Looks like I am off to the races with my 'new' car. Having a overheating problem that does not make sense to me:
The car starts and runs up to operating temp and beyond at idle. Thermostat is working fine. The car shows some circulation in the rad. If I take it out on the road in will run hotter than usual but will get hot, then cool a bit on the gauge when cruising; however, it's still operating above the normal temp. In traffic it continues up, my guess is that it will overheat if i were to push it in heavy traffic.
Here's the dilemma: if the pump wasn't working it should keep getting hotter, and it the rad was blocked it should do the same thing. Am I correct or am I missing something? maybe the rad partially blocked and cruising allowing for just enough cooling to keep it from overheating? Pump does not leak and there is no noise from it so my guess is it is working.
The rad is an orig chrysler rad, either the one from the factory or a factory replacement.
Any ideas/input?
Any ideas/input?
