Painting rims
MoPar~Man
Ontario, Canada
I've used rustoleum (gloss black) to paint the inside of aluminum rims after I took a wire wheel to it and wiped it down with laquer thinner. Seemed to work well. No runs, no drips, no errors. :)
bnz84
Maryland
To get a uniform surface (no brush strokes) I would think you would have to either thin it with solvent or mix in a paint conditioner like Penetrol.
MoPar~Man
Ontario, Canada
I was satisfied on how the rustoleum flowed and created an even, flat surface. No brush strokes. I did it in the garage. Maybe don't do it in bright sunlight with the rim being heated by the sun until after you've applied all the paint.
(correction, it was tremclad, not rustoleum)
73Coupe
San Luis Obispo, CA
Oil/Alkyds always lay out nicely in the correct temperature range. And runs can be corrected before they dry.
Benjamin-Moore "super spec" alkyd urethane is a step up, and you can get this color matched.
POR-15 also lays out really nice as a base coat.
Like sprays, you'll need primer and a couple top coats with sanding in between to make it really nice.
EDIT: use an oil / alkyd primer on ferrous metal only. Aluminum or zinc require special primer.
MoPar~Man
Ontario, Canada
I have to make a correction. It wasn't rustoleum, it was Tremclad. I had a look at the can today, it is Tremclad "rust paint". I bought a similar Tremclad can, silver or aluminum, for when I paint the inside of my 18" 300m rims. I think they're oil based.
300rag
Calgary, Alberta, Canada
Tremclad is a Rustoleum brand. Sold as Tremclad in Canada and Rustoleum in the US.
Imperial dude
Ohio
Benjamin Moore super spec is good paint, we use it a lot on metal doors and frames, it almost looks like it's been sprayed
Use a good brush, maybe a Purdy 2 inch sash brush, if you have a Sherwin Williams distributer near you he (or she) can help you pick out the right brush, you won't get a good job with a $2 Big Lots brush
And defiantly clean, dry, grease free, and paint in the shade, and let bake in the sun to dry
73Coupe
San Luis Obispo, CA
Good call on the brush. Black China bristle is what I had best results with.
polaratherapy
Rockwood, Ontario
What are the pitfalls of just using a rattle can and then a nice clear coat, Dupli Color have sets to change chrome rims to let's say copper/ chrome and then clear coat.
fury fan
Indianapolis
For brush painting, a quality brush of the correct type to match the paint makes a HUGE difference.
edit - As others have already mentioned. I'm just agreeing whole-heartedly.
