First major task at hand with my 300, fix the power steering leak. After cleaning up the old grease and oil I found where the PS fluid is leaking from (hopefully the only leak). It looks like a job that may be tackled without removing the steering gear. It seems the two nuts that hold the "hose bracket" can be removed and whatever gasket is underneath could be replaced.
Based on these pictures, any suggestions or input if it is possible to fix this without removing the gear? It looks like this "hose bracket", which is where it appears to be leaking, is new/newer as it is shiny and not painted black like the rest of the steering gear.
Any input is greatly appreciated!
