The title of my rant has to do with the hyd valve adjust on the steering gear......this absurdly ridiculous small adjustment that results in self steer first R then L, even though I have scribed the flat surface and tried to move it one RCH. So that is why I will try the dial indicator so that I can totally control the amount of movement in future. Not sure my steering gear is well, since I cannot properly adjust the gear play.....first one I have ever seen that gets tight and still has play, gear backlash. And further, the input shaft will move axially when running thru the gear backlash, so there may be some internal problems. I have talked to three rebuilders with not much help on these small points. But, still want to do my best before sending this one into the abyss. There is no slop in the input flex joints, nor any I can see in the steering linkage below.....I am looking at the output of the pitman steer box arm for fine adjust, not the wheels. What I cannot determine, is whether this axial play in the input, could cause some problems with the hydraulic spool valve, if the piston, etc is loose.....One of these days I will try a road test after doing my best to settle things down.
