MrMoparCHP
I posted this in the FABO forum just curious if anybody here has any ideas.
Power Steering blowing out vent
The other day I too my car for a drive and noticed power steering fluid everywhere.
I checked the cap and it was kind of loose, tightened it, same results.
Added a second gasket, no change.
Each time I add fluid to mid point on the filler neck and each time it blows it out till it is low and moaning.
It is a TRW in a 67 Barracuda w/273
Thanks,
Alan
Followed up with...
The other day I put a different pump in that I thought was from a car that had no issues. The plan is to send in the original for rebuild.
After I get the pump in I jack it up and with the engine running I turn the wheel lock to lock many times, first slow then increasing.
On the test drive it is jerky at points primarily at an idle.
I just need to keep the car mobile while the pump is at the rebuilder, I'm just trying to figure out if I have a bigger problem.
Steering gear is the factory unit and has never been worked on along with the valve assembly on the gear, car probably has 400k on it.
Alan
Thanks,
Alan
Followed up with...
Alan
