Power Window Motor Rebuild
Mopar_Mudder
Wisconsin
Had one of the power window motors in my 1962 Imperial that didn't work. Tore it apart and found that the commutator was all cracked and falling apart. Found a new one to replace it and works perfect now. Also you can easily remove the motor with out taking all the arms and tracks out, just one bolt that hold a band in place and the motor comes out.
Here is the commutator that fits:
DEYISI 18 x 8 x 14.5(15) mm 10P Teeth Copper Hook Type Electrical Motor Commutator​
I got 5 for $15.00 at Walmart of all places. I could have bought 1 but figured if I screw one up I would have extra. Pretty cheap fix as long as you are OK with soldering.
