rexus31
I think the front passenger's side window motor quit. Has anyone successfully replaced one with the regulator still in the car?
I have replaced no less then 4 motors in my Imp this past year and you can't even access the bolts that attach it to the regulator without removing it from the door. The first one or two that you do can be a challenge but it really is the easiest way to do it. Plus it gives you the best opportunity to grease everything up proper on reinstall.
You will want to clamp the main arm to the door, or block it so it can't move. Once you remove the 3 bolts that hold the motor in place, and remove the motor, the BIG assist spring will come down like a tomahawk! First time I discovered this I had my arm inside a rear quarter panel of a 68 Coronet. I was there by myself and it took me about an hour to get free...cut my arm up pretty bad too.
Glass does not need to come out to take reg out, it really is the best and easiest way to do it safely. Did you find new replacement motor?
My understanding is that new ones can be had and I would recommend it as I haven't had much success with the used ones lasting more then a few weeks of use before the big chunk of rubber separates from the gear.
You getting power on both sides of the switch?
