1. Lowapproach
    Lowapproach New Member
    41
    27
    Dec 15, 2019
    Northwest
    Looking at front suspension rebuild kits, which do you guys prefer?
  2. saylor
    saylor Senior Member
    2,865
    1118
    Mar 31, 2013
    GARLAND TEXAS BABY !!!
    P-S-T bump stops failed on me in less than 5 years and they gave me grief about replacing them. they want me to ship them back, and they wont stand behind 'dry rot' if they determine thats the cause. whatever the hell that is.
    pictures were not good enough for them. meanwhile i found my 50 year old ones and stuck them back on . . . other than that the rest of their stuff has done OK.
    try not to die -
    - saylor
    • Like Like x 1
  3. Newport 66
    Newport 66 Old Man with a Hat FCBO Gold Member
    6,826
    4275
    Aug 6, 2017
    Lancaster, WI
    I bought leaf springs and hangar kits from Firm Feel for the Newport. 3 yrs ago, so far so good.....sorry no front suspension experience either way.
    • Like Like x 1
  4. Lowapproach
    41
    27
    Dec 15, 2019
    Northwest
    Thanks for the feedback.
  5. Lowapproach
    41
    27
    Dec 15, 2019
    Northwest
  6. polarus
    polarus Senior Member
    1,860
    859
    Feb 22, 2013
    I went with Firm Feel, I like the quality and the fact that you can upgrade some parts like tie rods and upper control arms.
    • Like Like x 2
  7. Lowapproach
    41
    27
    Dec 15, 2019
    Northwest
    Thanks, that helps.
  8. 1Fury1
    1Fury1 Slab Side Slacker FCBO Gold Member
    1,006
    782
    Dec 17, 2011
    Carstairs, Alberta
    I bought a complete firm feel front end and rear suspension in 2014 including tubular uca’s, tie rods, idler arm, Bilstein shocks, front sway bar, rear leafs and brackets, all polyurethane bushings etc etc. Quality stuff and after 6000 miles no complaints whatsoever.
    • Like Like x 2
    • Agree Agree x 1
  9. Lowapproach
    41
    27
    Dec 15, 2019
    Northwest
    Thanks, how are the polyurethane bushings as far as noise and ride quality? I want firmer than stock but not jarring.
  10. polara71
    polara71 Old Man with a Hat
    42,151
    9085
    Nov 16, 2010
    Here & There
    The Bilstein shocks will do that . I replaced everything with Moog parts but the Bilsteins and a rear sway bar.... Stiff!
    • Agree Agree x 2
    • Thanks! Thanks! x 1
  11. Lowapproach
    41
    27
    Dec 15, 2019
    Northwest
    I’ve always preferred kyb shocks, they seem to ride better than the Bilsteins.
  12. Davea Lux
    8,344
    2026
    Mar 27, 2017
    Cornelius Or
    There are other threads here about poly bushings. For a street car, poly will give a tighter performance because poly does not distort. The factory bushings were rubber for a good reason. The rubber absorbs road shock which keeps critical suspension components from excessively flexing and eventually breaking. Rubber also works well to suppress road noise. I would never run poly on upper, lower control arms or strut rods, I did that once and decided to sell the car because it rode like an oxcart and was very prone to squeaking and transmitting lots of road noise You can run poly on the stabilizer with good results for a firmer and flatter feel on corners. You can also increase rear stability by running poly on the bushings at the back of the rear springs.
    There have been lots of problems with the replacement rubber bushings made overseas due to the use of inferior rubber compounds and poor quality control. I would try to find quality US sourced replacements.
    • Like Like x 1
    • Agree Agree x 1
  13. 1Fury1
    1,006
    782
    Dec 17, 2011
    Carstairs, Alberta
    I have a firm ride with virtually no roll even in fast corners, and yet I wouldn’t call the ride too stiff at all. Still have good suspension on road dips and bumps. I would recommend a light coat of silicon grease on the rear leaf bushings at installation, something I found out later. They still squeak though it seems a little less every year.
    • Like Like x 1
  14. Lowapproach
    41
    27
    Dec 15, 2019
    Northwest
    Thanks for the confirmation, that was my understanding as well.
  15. thrashingcows
    thrashingcows Senior Member
    2,975
    1279
    May 15, 2012
    British Columbia
    I have a OEM rubber PST front end rebuild on my 68 T/C wagon, with a big aftermarket 1.125" or maybe 1.25"? front sway bar with poly bushing from firm feel. I have 15K miles on everything and it is holding up OK, although there is a "clunk" in the front end that showed up about 3 -4 years ago and I have been too busy with life to get in there and find the problem...I suspect it is the the strut rod bushings since it makes the noise mostly under braking.
  16. LocuMob
    LocuMob Fluid Technician with a hat FCBO Gold Member
    12,111
    7972
    Oct 31, 2013
    Blue Earth Mn
    I used the P-S-T kit when I redid the Polaras front end. Went together fine and I haven't had any issues. I'm going to go over it visually after hearing a couple issues this past year, but only out of curiosity. The car drives fine and handling is as it should be. I put KYB's all around and they work fine. I'd like to add a rear sway bar to the car though. I'll be putting another P-S-T kit on my Dart pretty soon.
    • Agree Agree x 1
  17. Zymurgy
    Zymurgy Old Man with a Hat FCBO Gold Member
    6,278
    4856
    Sep 14, 2012
    London, Ohio
    Combination. I did the PST suspension 6 years 12,000 miles still happy. I put feel firm front sway bar and would highly recommend their rear sway bar too. I did it a year later.
    I would recommend having your steering box rebuilt too. It was the worst part of my front suspension, and the most expensive but well worth it.
    • Like Like x 1
  18. Lowapproach
    41
    27
    Dec 15, 2019
    Northwest
    Thanks for the info, the steering box is on my list of the things to do.
    The list is long and getting longer!
    • Agree Agree x 1
  19. Zymurgy
    6,278
    4856
    Sep 14, 2012
    London, Ohio
    It will all be worth it in the end. I really can't get over how nice these big old boats can handle, with the right equipment. I expected a nice ride.
  20. Cbodyuser
    Cbodyuser New Member
    6
    1
    Jan 18, 2012
    I have yet to use P-S-T or FirmFeel but from what I have seen and read, FirmFeel is the way I would go. In spite of higher prices for FirmFeel.
