Pull my hair out?! $@$_&- carburetor.
Early C Bodies - The Slab Side Years
  1. Joseph James
    Joseph James Well-Known Member
    562
    286
    Jul 21, 2018
    Asheville, NC
    Took a friend from work home as his motorcycle was in the shop. Car sat 30 minutes. Had to floor it to get it to crank. It took 30 minutes of dying and cranking before it would run. We looked under the air cleaner at one point when it died idling. Gas out the vent, gas from accelerator pump linkage, gas from bowl vent gasket.
    Two miles from my house to his. It died a dozen times. Had to floor it each time to get it to crank.
    Mixture screws are out 1 turn. Curb idle is backed all the way out. Idles 1000 like that. I'm ready to put the carb in the trash.
  2. Davea Lux
    Davea Lux Senior Member FCBO Gold Member
    4,246
    1076
    Mar 27, 2017
    Cornelius Or
    You have a bad float or a bad needle valve, mixture screws have nothing to do with the carb pissing gas out the top and sides. Take the carb apart and check for fuel logged floats or a piece of junk under the needle valve(s).
    • Agree Agree x 8
    • Thanks! Thanks! x 1
  3. 70bigblockdodge
    70bigblockdodge Old Man with a Hat FCBO Gold Member
    11,055
    4363
    Jan 19, 2013
    Avonmore Pa.
    You need new floats and needle and seats.
    • Agree Agree x 3
  4. 413
    413 Active Member
    258
    92
    Jan 28, 2019
    NW USA
    No, he needs to find the problem. Replacing parts may not fix it.
    Is the fuel pressure too high? Is dirt or a bit of rubber hose stuck in the needle & seat?
    Please tell us what pump and carb you have! And the history. When was the last time you worked on anything fuel related on this car?
    • Agree Agree x 1
  5. Joseph James
    562
    286
    Jul 21, 2018
    Asheville, NC
    Well that sucks since it is a remanufactured carb.
    It only acts up when hot. If I drive straight home I can make it. If I stop for any reason, I'm screwed.
  6. Joseph James
    562
    286
    Jul 21, 2018
    Asheville, NC
    I have a whole thread about this train wreck.
    I had the carb apart three times. Last time I set floats. It was clean as a whistle. Float level was 7/16 instead of 5/16.
    I wonder if this could be vapor lock?
  7. Davea Lux
    4,246
    1076
    Mar 27, 2017
    Cornelius Or
    My best guess is either the float level is set too high by the rebuilder or the is a piece of dirt under the needle valve, either way, it needs to come apart.
  8. Knebel
    Knebel Senior Member
    1,160
    214
    Mar 21, 2013
    Beaverton, Oregon
    ah...vaporlock or boiling fuel in the bowl. remedy for me years ago was electric fuel pump and a phenolic spacer.
    • Agree Agree x 1
  9. Davea Lux
    4,246
    1076
    Mar 27, 2017
    Cornelius Or
    Vapor lock will not cause the carb to piss fuel. While you have it apart, check to be sure the brass part of the needle valve assembly has a gasket on it and that it is screwed in tight.
    • Agree Agree x 1
  10. Davea Lux
    4,246
    1076
    Mar 27, 2017
    Cornelius Or
    Have you checked the heat riser, if it is stuck shut it can cause fuel to boil in the carb.
    • Agree Agree x 1
  11. mr. fix it
    mr. fix it Old Man with a Hat
    6,338
    3770
    Aug 14, 2013
    Welland, ON
    sounds like a bad vapour lock happening if you shut down but it's hard to diagnose from here without seeing the car in person...
  12. Knebel
    1,160
    214
    Mar 21, 2013
    Beaverton, Oregon
    does it only happen after you heatsoak the engine and want to restart or lets say if you drive for a while will it be fine and then starting to act up?
  13. Davea Lux
    4,246
    1076
    Mar 27, 2017
    Cornelius Or
    If you are getting 1000rpms with the curb idle all the way out, the fast idle screw on the choke cam is probably not set properly.
  14. Joseph James
    562
    286
    Jul 21, 2018
    Asheville, NC
    So, if I drive to work no problem. Drive home is ok.
    If I stop for gas or anything and try to restart, it goes all to hell.
  15. Joseph James
    562
    286
    Jul 21, 2018
    Asheville, NC
    Yes
    I'll add that the carb has a needle with a flat, rubber type end. Never seen one that wasn't pointed.
    I have cleaned this carb several times. It has always done this puking of fuel.
  16. 70bigblockdodge
    11,055
    4363
    Jan 19, 2013
    Avonmore Pa.
    A CARBURETOR WITH FUEL COMING OUT THE TOP IS A FLOAT, AND OR NEEDLE AND SEAT PROBLEM.
    Read that three times and then go fix it. Don't dream shit up that is not the problem.
    You reman, carb cleaner in a can rebuild is no good. Get a good kit from a reputable supplier (not authorized zone etc.) Or send it to member here carb shop.
    It is notbecause your tank is too full, or you pump is pumping too much, or because you parked facing downhill. If you don't understand fluid dynamics then STFU.
    • Agree Agree x 2
  17. CBODY67
    CBODY67 Senior Member
    3,746
    846
    Mar 27, 2011
    Obviously, the car wants to "drive". When you stop it, after driving, it's just telling you it doesn't like to sit still.
    Better get an OIL CHANGE SOON, if not SOONER! Gasoline is a solvent to motor oil.
    It's not even summer yet, and you've having these problems???
    When you do the carb rebuild, make sure that the air bleeds on the top of the venture cluster (or, if a Holley 4bbl, the air bleeds on the primary side, just inside of the air cleaner "circle") are OPEN and clear. When they get plugged or decrease in size, that makes that particular fuel circuit go full rich. Even to the point that fuel will pour out of the venture when the car is running. DO make sure that the related gaskets don't block these holes, either!
    On the float setting, if there is a "range" of dimensions, aim toward the lower level rather than otherwise. Won't affect performance, but it might help decrease any fuel percolation issues that might be happening. IF that's what is happening.
    BUT, get that oil changed sooner than sooner!
    CBODY67 .
  18. Dana
    Dana Active Member
    239
    181
    Sep 17, 2011
    Ohio
    I ran into a problem very similar to yours on a 52 buick roadmaster. It was that style N/S. Some of those do not have the windows cut in the side of the brass seat, so the fuel can only enter around the needle and out the end of the tube. (The tube being the end of the seat.) So, with the backpressure of the fuel only having one direction to go, it lifts the needle off the seat intermittently. The intermitten stuff is always the hardest to diagnose. I machined 2 small windows in the brass tube, and WALA. Anyway, just a thought. if you get it apart, post some pics.
    • Thanks! Thanks! x 4
  19. marty koirtyohann
    marty koirtyohann New Member
    42
    11
    Aug 2, 2017
    washington,mo.
    what is it a HOLLEY? it sounds like it .u have a flooding problem try changing the needle & seats if they r good then the float is out of adjustment .I had the same problem we put everything new in it & it would still flood sometimes I talked to a shop recommended by holley Daytona parts . the uy there told me to set the floats 1/16-1/8" lower (0.0625-0.125") that fixed it they also rebuild carbs too Daytona Parts Home
  20. fins2fuselage
    fins2fuselage New Member
    22
    4
    Jan 15, 2016
    Nebo, NC
    Joseph,
    You may be experiencing heat-soak; that is when heat saturates the carburetor and the fuel boils in the bowl. This occurs due to the use of gasohol (which boils at a lower temp) and/or due to the engine temperature getting too high. Try lifting the hood when you park your car and see if that helps; if so, it is heat-soak.
    My suggestions to actually remedy the problem: use ethanol-free gasoline and get the engine temp down as much as possible. Ethanol-free may be found here: Ethanol-free gas stations in the U.S. and Canada
    Engine temp can be lowered by many means, including lower temp thermostat (160 deg.), fan with more blades and a fan clutch, use of a fan shroud, larger radiator, lower heat range spark plugs and backflushing the cooling system.
    Best of luck with your problem.
    Jeff Dreibus
    The Old Carb Doctor
    Old Carb Doctor
    • Agree Agree x 1
