I have a Holley spread bore carburetor. I've read where the Holley carburetors are very sensitive to fuel pressure and it needs to be around 6 psi (no higher than 8 psi) or the carburetor gets overloaded with gas. My mechanic claims you don't need a fuel pressure regulator if you have a mechanical fuel pump. But I've heard a lot of guys use a fuel pressure regulator on carbureted cars and why would Holley manufacture a low pressure fuel regulator? (unless the same guys are using an electric pump with a carburetor).
Does any one on this board use a fuel pressure regulator with a carburetor and mechanical fuel pump? I'm looking for a combination fuel pressure regulator / fuel pressure gauge. Paul
