Question on trunk floor drop down
Davews
Friendship Wi
Can someone tell me if a 72 or 73 C body trunk floor drop down will fit a 69 C ? I have the lower qrt but need those extensions....thanks, Dave
They won't be identical, but you should be able to make them work with some modifications. Certainly would be easier to adapt the '72-'73 than to make up a set from scratch.
Jeff
Why wouldn't they be?
Not sure how this would work in your situation. However, I always just use velcro. It holds the box in great and makes it really easy to take the sub out. If you get a velcro set, or whatever it's called, you can adhesive or screw on the strips of fabric to the trunk then screw or adhesive the counterpart on the bottom of the box.
WHAT???? :wtf:
