RB Rocker Shims
Davea Lux
Cornelius Or
Does anyone have a line on the shims for stock mopar rockers? Need to rebuild a rocker set with new rockers and shims.
(Spacers between the rocker arms on the shaft? Or shims that go under the shaft as it mounts to the cyl head to decrease hydraulic valve lifter pre-load?)
The ones that go between the rockers, car had a well worn rocker shaft and the existant RH spacers are tapered slightly.
$12.00 @ Mancini's. Summit and Jegs are similar $. .015" thickness. If you mean the actual spacers, Mancinis has those too, couple bucks more.
